cruise control problem
Hi all,
I've just fitted an IMMO removed shark remapped ecu to my 02 plate vrs and am loving the extra power/torque however I have noticed hat cruise control has stopped working. I suspect its something to do with the remap and wondered if the CC needs reinstating via vag com, I've checked both ecu plugs and they're in tight. many thanks in advance.
The configuration for the CC is in the ECU. If you've swapped the ECU, then you will need to enable it in this ECU with VCDS
