2011 Octy VRS 2.0 tsi
Does anyone know if the new (2011) Octavia VRS steering can be adjusted with vagcom?
What sort of adjustment?
it can but a bit limited - you can adjust weighting and centralisation channel 44 i think
I have been reading about people increasing or more likely decreasing the amount of assistance in the steering to give a better feel.
Whilst my new suspension setup has improved most of my driving experience, on the motorway, It's still a bit twitchy, perhaps too much assistance.
You can't change the weight on the 2011 ones - function was removed 2007 ISH apparently :(
You can do centralisation but thats about it (I think)
Suggest toe in / out may get you more for what you're after?
OK, thanks for that. The new suspension mounts (WALK) increased caster by %0.05 but that wasn't enough to improve the straight ahead feel at speed. :sweat:
I think walk wont actually increase straight line stability except under acceleration or braking? lowering will decrease stability due to increased negative camber.
