Auto Unlock not working
Hi , my auto unlock stopeed working yesterday after i fitted cruise control. now when i get out the car i have to unlock using the fob. any ideas??? It used to unlock all doors once i took the key out of the ignition. VERY confused
It could be that when the coding was done for the cruise, something was done to the coding for the auto unlock. Do you have maxidot? If so you can check it and reset it using that. If not you will have to find someone with VCDS to have a look and check if there are any faults then reset it.
Ian
sounds like its been disabled during coding , did you use long coding?
Had this done today for the fault read. From what we looked at on the net we used the correct coding. Also when we had a look at the check boxes my auto unlock was ok... From the read below it shows something to do with Electrical Fault in Circuit.
Any ideas????
Sunday,17,June,2012,14:01:15:07792
VCDS Version: Release 11.11.3 (x64)
Data version: 20120401
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: TMBEH21Z682097616 Mileage: 152130km/94529miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine Labels: 03G-906-018-BMN.clb
Part No SW: 03G 906 018 EL HW: 03G 906 018 EL
Component: R4 2.0l PPD1.2 G 9953
Revision: --H52--- Serial number: SKZ7Z0G4591483
Coding: 0000072
Shop #: WSC 22013 576 90947
VCID: 73EFCD1412AE091
No fault code found.
Readiness: N/A
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0006786
Shop #: WSC 73430 790 00000
3 Faults Found:
00668 - Supply Voltage Terminal 30
008 - Implausible Signal - Intermittent
01309 - Power Steering Control Module (J500)
004 - No Signal/Communication - Intermittent
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1Z0 907 044 AB HW: 1Z0 907 044 AB
Component: ClimatronicPQ35 120 0600
Revision: 00120022 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 76E9F40001DC1C9
2 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded - Intermittent
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 00000005427547
Coding: 01880F030004140040110D000000000000087F075C000000000000000000
VCID: 71E3C71C68B23B1
Subsystem 1 - Part No: 1Z2 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 211107 022 0601
Coding: 00055223
Shop #: WSC 73430
2 Faults Found:
01049 - Supply Voltage Term 50
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 100
Mileage: 152005 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
OFF
Voltage: 12.75 V
OFF
OFF
ON
OFF
OFF
01598 - Drive Battery Voltage
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 3
Reset counter: 86
Mileage: 151259 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 13.35 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: Q4 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD1MCABJ
Coding: 0020788
VCID: 3D7B2B2C646A8F1
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BN HW: 1K0 953 549 BN
Component: J0527 051 0100
Coding: 0000042
VCID: 7F0711242EE65D1
7 Faults Found:
01044 - Control Module Incorrectly Coded
00885 - Ignition Switch (D) Terminal 50
00888 - Wiper Switch for Intermittent Operation (E22)
014 - Defective - Intermittent
00576 - Terminal 15
00883 - Ignition Switch (D) Terminal S
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1Z0 920 912 E HW: 1Z0 920 912 E
Component: KOMBIINSTRUMENT VD1 1610
Revision: V1610056 Serial number: SKZ7Z0G4591483
Coding: 0003401
Shop #: WSC 00011 888 96745
VCID: 377739044656A51
1 Fault Found:
01299 - Diagnostic Interface for Data Bus (J533)
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 4
Reset counter: 99
Mileage: 1048575 km
Time Indication: 0
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 P HW: 1K0 907 951
Component: J533__Gateway H16 0191
Revision: H16 Serial number: 2000K07A30801F
Coding: E9807F060002021303
VCID: 346D0E0857204E9
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VD1 1610
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1T0 959 701 D HW: 1T0 959 701 D
Component: Tuer-SG 006 1204
Coding: 0000756
VCID: 38753A384B48AA9
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 M
Component: EPS_ZFLS Kl.074 H08 1901
Shop #: WSC 73430 000 90108
VCID: 36693400415C5C9
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 98801A085283007F3F04850540085F96907CA0
VCID: 830F1DD4C20EB91
Subsystem 5 - Part No: 1Z0 951 171
Component: Innenraumueberw.008 4801
Coding: 00000000
Shop #: WSC 22013
Part No: 1K0 951 605 D
Component: LIN BACKUP HORN H07 9001
Component: NGS n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1T0 959 702 D HW: 1T0 959 702 D
Coding: 0000756
VCID: 39733F3C7042B31
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 1Z0 035 161 C HW: 1Z0 035 161 C
Component: Radio FO3 019 0040
Revision: 00019000 Serial number: SKZ7Z3G0118373
Coding: 0000402
VCID: 2E591C60B90C649
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 J HW: 1K0 959 703 J
Component: Tuer-SG 006 1201
Coding: 0000144
Shop #: WSC 73430 790 1012544
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 J HW: 1K0 959 704 J
Coding: 0000144
End ---------------------------------------------------------------------
Hmmm, looking at that I'd be tempted to say you've got a dodgy connection somewhere from fitting the cc stalk.
