Rear Washer Problems
hey guys my rear washer has stopped working and i have read the guide on how to fix it with the 4 points in which the problem could be, but for the life of me i cant find a problem. the pump works fine as i can here it working when pushing the stalk. the water seems to drip from the rear left hand wheel arch. i have removed the boot trims and cannot see any broken connectors or fluid?!?!?! this is really starting to frustrate me, if anyone could provide some insight on what to check or look i would be very greatfull
p.s i have checked the inside of the back passenger door trim and cannot see any wetness or leaks there
james
its fixed people the pipe decided to relocate itself so after some mre looking (tug and pull) i have fixed the two piped and the rear wiper work again :)
Could be blocked, have you tried a pin in the jet?
