DPF Regen Info (Based on 2.0 CR Engine)
Hi
Recently i have been investigating some issues i have been having with my engine and found this info about DPF Regeneration which i thought may be of info to some of the users on here.
Enjoy....
Dallan
Firstly if needed there is a warm up phase:
Warm-Up Phase
To heat up a cold oxidation catalyst and particulate filter as quickly as possible and thus bring them to
operating temperature, the engine management system introduces a post-injection after the main
injection.
Basically then there are 5 Levels of Regeneration
Passive Regeneration
Active Regeneration
Customer-Initiated Regeneration Drive
Service Generation
and Distance Regeneration
The first 4 are based on the measured load on the actual DPF and the final one is NOT
“Distance regeneration” is a distance-dependent regeneration of the particulate filter. The Engine
Control Module (ECM) J623 initiates an active regeneration automatically if during the last 466 to
621 miles (750 to 1000 km) of travel no successful regeneration has taken place, regardless of the load condition in the diesel particulate filter.
Distance regeneration serves as additional safeguard to minimize the load condition of the diesel
particulate filter.
Update with info on each type:
During passive regeneration the soot particles are continuously burned without the intervention of
Engine Control Module (ECM) J623. This occurs primarily at higher engine load, such as
in highway driving, when exhaust gas temperatures range from 662°F to 932°F (350°C to 500°C).
At these temperatures the soot particles are converted into carbon dioxide through a combustion
reaction with nitrogen dioxide.
Active Regeneration:
In a large portion of the operating range the exhaust gas temperatures are too low for a passive
regeneration. Because soot particles can no longer be eliminated passively, soot accumulates in the
filter. As soon as a specific soot load has been reached in the filter, the Engine Control Module
(ECM) J623 initiates an active regeneration. The soot particles are burned off at an exhaust gas
temperature of 1022°F to 1202°F (550°C to 650°C).
Active Regeneration Function
The soot load of the particulate fi lter is calculated by two pre-programmed load models in the Engine
Control Module (ECM) J623. One of the load models is determined from the driving profile of the user and the signals from the exhaust gas temperature sensors and Heated Oxygen Sensor (HO2S) G39.
Another soot load model is the flow resistance of the particulate filter. It is calculated from the signals
of Exhaust Pressure Sensor 1 G450, Exhaust Gas Temperature (EGT) Sensor 3 G495, and Mass Air
Flow (MAF) Sensor G70.
Customer-Initiated Regeneration Drive:
An exhaust gas temperature high enough for particulate filter regeneration is not reached when
the vehicle is only driven for short-distances. If the load condition of the diesel particulate filter reaches a
threshold value, Diesel Particle Filter Indicator Lamp K231 in the instrument panel will light up.
This signal prompts the driver to perform a regeneration drive. The vehicle must be driven for a
short period of time at increased speed to ensure that an adequately high exhaust gas temperature
is reached. The operating conditions must remain constant over the period for a successful
regeneration.
Details of the driving behavior required when the Diesel Particle Filter Indicator
Lamp K231 comes on can be found in the Owner’s Manual
Service Regeneration:
If the regeneration drive is not successfully completed and the load condition of the diesel
particulate fi lter has reached 1.41 ounces (40 grams), Diesel Particle Filter Indicator Lamp K231 and Glow
Plug Indicator Lamp K29 will light up simultaneously. The text “Check Engine – Workshop” will appear
in the instrument panel display.
This prompts the driver to visit the nearest service shop. In this case, the Engine Control Module
(ECM) J623 blocks active regeneration of the diesel particulate filter to prevent damage to the filter and
the particulate filter can only be regenerated by a service regeneration with the VAS 5051.
When the load condition reaches 1.59 ounces (45 grams), service regeneration
is no longer possible. Because the danger of destroying the filter is too
great with this load, the filter must be replaced.
Edited by Dallan
Hi
ENJOY....???...
Dallan
Warm-Up Phase
injection.
Active Regeneration
Service Generation
particulate filter.
enjoy ???......i wish i could 'enjoy' the dpf on my pd vRS..... :wall:
Yeah maybe Enjoy was the wrong choice there
"Happy Reading" :p
"Happy Reading" :p
:thumbup:
Great information, do you have the text that supports the other four typres of regen?
Tip top tastic Dallan cheers for the info as Mr Silver said above it would be good if you have any more on the others?
Will stick up the others later when I get on with laptop
Updated first post with the details of the other cycles
Hi Dallan
Very good information, thanks; best ask, would you object if the link was put on a couple of caravan forums?
Chris
If anyone wants the full pdf, PM me your email it has loads of info in it 90 odd pages
  • 2 months later...
Hi
Enjoy....
Dallan
Warm-Up Phase
injection.
Active Regeneration
Service Generation
particulate filter.
regeneration.
Technician @ Liverpool Skoda has told me and I quote
" Regeneration will only take place if there is more than 11 litres of fuel in the tank "
I will investigate this further and report back in a short while. :think:
  • 9 years later...
On 01/07/2012 at 05:51, Dallan said:
Hi
Enjoy....
Dallan
Warm-Up Phase
injection.
Active Regeneration
Service Generation
particulate filter.
regeneration.
Thanks for the info Dallan, much appreciated.
