PO252
Help I've got Octavia 03 1.9tdi 90bhp. Error code PO252 has anyone had this before or know how to fix it please?
normally associated with blocked fuel filter so change that and clear code
hth
+1
16636 P0252 Injection Pump Metering Control (A) Range/Performance
If this is the only code related to the IP, then it's likely to be a clogged fuel filter.
Cheers thanks very much,wasn't sure if it was a fuel pump problem. Much appreciated
