Favorit/Felicia hub question?
I'm looking to do teflontom's 256mm mondeo/kia vented brake upgrade but I have a mk1 favorit with 4x98 wheel pcd so 4x100 discs would need drilled out to fit.
I was wondering if felicia hubs are the same apart from being 4x100 and whether they're interchangeable with the favorit ones?? The favorit driveshafts have 22 teeth if that helps.
I don't think they are, or rather that all of them are. James (fruitbat) did a big brake conversion on his (using Wilwoods) and I seem to recall something about the brake lugs being different on some hubs or something like that. Might be worth a PM to him, as I'm not 100% on the specifics, and they may have even been different Felicia hubs. Or something!
if you fit the complete steering knuckle then yea it all works (remember to do tracking afterwards too) some early favs had different caliper offset and lug spacing so best just swapping the whole unit over from a felly.
Cheers guys!!! :)
