VCDS Errors reported
Hello,
I ran the Diagnostics on my Car yesterday, which is a Octavia II 2004 and the result is follows (posting only the Faults). What do they mean?
Address 16: Steering wheel	 Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AQ HW: 1K0 953 549 AQ
Component: J0527		 035 0070
Coding: 0002042
Shop #: WSC 73430 790 00000
VCID: 810D0137A199
Part No: XXXXXXXXXXX
Component: E0221		 002 0010
1 Fault Found:
00888 - Wiper Switch for Intermittent Operation (E22)
	 014 - Defective
1.) Wiper Stalk needs replacement?
Address 42: Door Elect, Driver	 Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1T0 959 701 E HW: 1T0 959 701 E
Component: Tuer-SG		 005 0946
Coding: 0001014
VCID: 397D29D709C9
1 Fault Found:
00120 - Outside Warning Light/Door exit Light Driver Side
	 012 - Electrical Fault in Circuit
2.) I have actually fitted non-CANBUS compatible LED's, could this be a problem?
Address 46: Central Conv.	 Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0202
Revision: 00020000 Serial number: 00000000000000
Coding: 01801A085283007F3F0285050008DF01807C00
VCID: 83010B3FBB85
Component: Sounder n.mounted
Component:	 NGS n.mounted
Component:	 IRUE n.mounted
1 Fault Found:
00896 - Trunk Lock Unit (F256)
	 008 - Implausible Signal - Intermittent
		 Freeze Frame:
			 Fault Status: 00101000
			 Fault Priority: 4
			 Fault Frequency: 2
			 Reset counter: 120
			 Mileage: 40648 km
			 Time Indication: 0
			 Date: 2000.00.00
			 Time: 18:38:48
3.) No idea!
Address 52: Door Elect, Pass.	 Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1T0 959 702 E HW: 1T0 959 702 E
Component: Tuer-SG		 005 0924
Coding: 0001014
VCID: 3A7F36DB0CCF
1 Fault Found:
00121 - Outside Warning Light/Door exit Light Passenger Side
	 012 - Electrical Fault in Circuit - Intermittent
4.) I have actually fitted non-CANBUS compatible LED's, could this be a problem?
Address 72: Door, Rear Right	 Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 J HW: 1K0 959 704 J
Component: Tuer-SG		 005 0905
Coding: 0000144
Shop #: WSC 11033 304 1012575
VCID: 387B2CD332C3
1 Fault Found:
00103 - Right Rear Interior Locking Button (E311)
5.) No idea!
Thank you!
Clear the codes and see which ones come back.
Cleared the existing codes and did a re-scan, and now, just 1 Fault remains, which is:
Coding: 0000144
VCID: 387B2CD332C3
1 Fault Found:
Could it be a problem with the Window Switch?
Seems like it could be a problem with the central locking in the door.
It's the individual door lock/unlock switch on the right rear door panel.
Does the backlight for the switch work?
If it doesn't check the brown wire to the switch.
If it does check the brown/green wire to the switch.
To test the switch disconnect it and and measure the resistance between pins 1 and 4.
In the middle position it should be open circuit.
In one direction it is a short circuit.
In the other direction you should measure about 200ohms.
@rwbaldwin
Thank you, will check and update
I checked the Switch, works perfectly well so I guess the fault is not in the Switch but elsewhere. Pointers please???
If you clear the fault again, does it come back?
That fault code it very specific. It can only be the switch, the wiring or VERY RARELY it can be the door control unit.
When you checked the wires, did you unplug the connector on the door control unit?
I cleared the code, but it came back again and again.
I checked it by disconnecting the Connector. So I guess it's a problem with the Door Controller then!
  • 2 years later...
Sorry to resurrect an old thread but I have a question related to some of the codes in this thread to anyone who has VCDS and non-canbus LEDs fitted internally please.
I too get the errors 00120 and 00121 mentioned above which clear and come back after I open the door.  I too reckon they are to do with non CANBUS leds fitted to my car, especially as I have similar and symmetrical faults 00131 and 00132 for my puddle lamps and 00061 for my footwell lights which all also have non CANBUS leds fitted.
Do others get these faults too?
Thanks in advance
Adam
Scans of modules 9,42 and 52 attached for reference:
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-H.lbl
   Part No SW: 3C0 937 049 AJ    HW: 3C0 937 049 AJ
   Component: Bordnetz-SG     H54 2202
   Revision: 00H54000    Serial number: 00000005746284
   Coding: E58A8F311004140043110D00000000008009FF0F3200000C000000000000
   Shop #: WSC 73430 790 12345
   VCID: 71EF90F2688A17A9905-8024
   Subsystem 1 - Part No: 1Z2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 140408 022  0601
   Coding: 00055223
   Shop #: WSC 73430
   Subsystem 2 - Part No: 1K0 955 559 AF  Labels: 1K0-955-559-AF.CLB
   Component: RLS     170408 046  0204
   Coding: 00471077
   Shop #: WSC 73430
1 Fault Found:
00061 - Footwell Lights
             Freeze Frame:
                    Fault Status: 01101100
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 101
                    Mileage: 192268 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        ON
                    Voltage: 11.95 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
   Component: Tuer-SG         006 1204
   Coding: 0001022
   VCID: 397F68D2707A9FE9685-806C
2 Faults Found:
00131 - Outside Door Handle Illumination/mirror Light Driver Side
   Coding: 0001022
   VCID: 3A7D77DE757C94F161F-806F
2 Faults Found:
00132 - Outside Door Handle Illumination/mirror Light Passenger Side
