skoda felicia odometer stuck after reseting by self
how do i get it fixed,stuck odometer, after reseting by me, fixed
and the sunroof leaks, how to fix?
Hello Arthur, welcome to the site.
You'll get more response posting in the right section. ie Felicia owners. This section is more for Skoda news, Skoda technical notices etc.
Good luck :thumbup:
fixing the stuck odometer itself is easy, but it is a little harder to get to it.
too bad you didn't bother to fill in your profile what TYPE of felicia you have.
but anyways, you have to take out the dash panel insert.
for that you have to:
1) take out 5 screws covered by plastic caps that hold the dash panel insert cover
2) Reach into the back of dash panel insert, press together joint at speedometer shaft connection from below and pull speedometer shaft out of speedometer
3) Pull out dash panel insert cover together with dash panel insert and unplug multi-pin connectors at the switches.
Unplug three multi-pin connectors on the rear of the dash panel insert by pressing together the two catches.
4)Take out dash panel insert cover to the left together with dash panel insert.
5) Slacken 2 securing clips and take out dash panel insert.
6) Take out the black plastic protective cover hold by a few screws.
7) Unscrew speedometer and take it out. You'll have to pry out the speedometer needle first.
Now it's just a matter of seeing which odometer gears are stuck or metallic springy slats are bent.
As for the sunroof leaking, have a look and read all the way the topic found at:
http://www.briskoda.net/forums/topic/151273-leaky-felicia-sunroof/page__hl__%2Bsunroof
Advanced search form button is our friend.
