G235 Sensor Fault?
The on going saga of error codes on my vRS has now thrown up a new one.
I get a flashing glow plug light and sometimes the engine management light on, no loss of power or limp mode.
VCDS scan has shown the error code as:
1 Fault Found:
001350 - Sensor 1 for Exhaust Temp Bank 1 (G235)
P0546 - 006 - Short to Plus - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100001
Fault Priority: 5
Fault Frequency: 149
Reset counter: 40
Mileage: 98434 km
Time Indication: 0
Date: 2000.00.00
Time: 11:20:00
Freeze Frame:
RPM: 2592 /min
Torque: 120.0 Nm
Speed: 22.0 km/h
37.05 %
Voltage: 14.13 V
Temperature: 26.0°C
Text: 1000 C
I tried doing check nn the Engine blocks via VCDS and the temperature of the sensor before the turbo reads at 1024 deg - but only when I put my foot down whilst the one in the DPF reads as normal.
I'm assuming it's a new G235 sensor but want to make sure I'm not missing a trick?
This is the final straw with this car, having spent near on £2k trying to resolve all the issues I've had over the last 2 years and it'll be going once this is fixed as I can't px it with the fault light on! Shame, as it was the car I really wanted but has turned out to be one of the worst I've ever owned.
Edited by Mattc3156
More than likely, I change quite a few for that fault. Just make sure your changing the right one, it's can get quite confusing.
Thanks for the reply - is it a DIY jobbie or worth getting a garage to do it?
They can be quite tricky to get into, also easier I think from under neath on a ramp.
Ok, no worries. Garage it is!
I swapped out a 235 on mine. Easy enough and not eye wateringly expensive.
