Oil on boost pipe from bottom of IC
I have checked out my Ic and on the lower pipe there is some oily gunk on the pipe joint, does this mean ive a wee boost leak?
I can hear a slight whislte on boost and its a wee bit smokey and the mpg is a bit poor...... sound like a cause?
Is there a way of tightening this stupid clip or is it a case of buying new hoses?
New oil seal.
However when relaxed the couplings do come apart a little and it's the lowest point of the system.
its because under pressure the pipes expand, so when you aint boosting they are slightly loose, nothing to worry about
Pretty sure the solid metal collar wouldn't change shape the slightest bit under boost, which is the part that makes the join? :giggle:
It doesn't change shape, but when boost is present the connection locks out tighter.
I accept apologises by a message on this thread or pm benjiman!
