Brake warning light and buzzer driving me mad !
For a few weeks now the warning buzzer has been going off every five minutes even though brake pads are fine ! Got mechanic to check brake fluid he says it fine , I would like to double check this but I cant see the min or max markings on the bottle . Is it possible to take it to the garage and get the warning light and buzzer turned off through vcds ? Any advice appreciated .
Don't turn off the warning light, that's madness.
It's going off for a reason, be it a duff sensor or something actually wrong. Get it fixed.
The buzzer sounds for worn brake pads or low brake fluid , I know the brake pads are fine and fluid is fine . I dont need a warning buzzer for brake pads or fluid I check them every month ,will get it checked again need to get it sorted its really annoying .
Try a new fluid bottle sensor it must be faulty, you may even have to change the bottle if it is built in.
If it is a faulty sensor won't a fault code be logged and readable with VCDS?
Seconded. I'd get a VCDS scan done and take it from there.
As said, it's going off for a reason - either a sensor malfunction or because something is actually wrong.
http://forums.vwvortex.com/showthread.php?2246459-DIY-How-to-get-around-the-brake-pad-wear-indicator-change-light-lamp-warning
I had the same problem, its caused by the cable connection to the pads on the near side front wheel.
I have just cut the plug off and stripped and twisted the wires together, wrapped insulating tape around them, and used small plasti strips to tie the wire out of the way, and cut the wear sensor wire off the pads result no more warnings
one of the cables came off the plug on the car side.
I will go to the scrappy's when I get time and get another plug and cut and solder both together
Edited by skippy41
a sensor giving a faulty reading doesnt always bring up a fault code, really the only way to determine if it works is to bench test it.
