Bluetooth retrofit with Bolero - location for mic wire
Looking at this today, but can't see where the mic cable should connect to. The guides I've seen either aren't based on the Bolero/VW equivalent or skip the step out for the mic cable entirely.
Can anyone assist? A photo would help, if someone has one.
Cheers,
Steve
I fitted bluetooth to my Octavia.
Bought a wiring loom from CarSytems.pl , this came with mic which connects to the new loom.
Check out the pic in the following link.
http://www.carsystem...over,id125.html
The new loom has male and female quadlock connectors on it. This fits onto existing quadlock connector you have removed from Bolero and then the other end plugs into the Bolero.
So there is no seperate connector for the mic on the back of the Bolero.
Hope that helps.
Sorted now - thanks guys.
