Skoda Symphony and Phatnoise
Hi,
Just wondering if anyone is running Phatnoise with your standard head unit?
Hi' date='
Just wondering if anyone is running Phatnoise with your standard head unit?[/quote']
No but I'm pretty sure it'll work fine as the symphony CD changer worked with my VW Gamma HU and VW Sat Nav which is now running a phatbox.
might be worth a chance so. Might order it and see how I get on......
If I had a normal HU I'd try it for you but the sat nav is a PITA to remove and refit.
Thanks Eddy. Its the new symphony in the Octy 2. Looks a bit different to the ones that I googled.
Hmmph, maybe a bit different then. But the phatbox works with Golf Mk5 HU's so there may still be hope.
The phatbox is cheap enough though and I doubt you'd have much trouble selling it on if needed.
Hmmph' date=' maybe a bit different then. But the phatbox works with Golf Mk5 HU's so there may still be hope.
The phatbox is cheap enough though and I doubt you'd have much trouble selling it on if needed.[/quote']
I have just installed a Phatbox in a 2003 Octavia with Symphony head unit and it was fine, Just unplug CD changer and then plug in Phatbox, it even fits in the same brackets
