Air con Problem !
Hi Guys
I ve a problem with my air con and i can not identify.
First of all my car had the problem with the compressor and i changed it with a new Sanden usa that works perfectly and cooling but i have a problem now that when i brake suddenly hard while driving or parking in reverse gear the air con doesn't blow cold air for just a second as if the compressor is disconnected and then reconnect again to blow cold air.
I have done the trick of pressing the ''ECON'' and the top right bottom and then 19 ^ 4 it gave me 10 rpm but when i brake hard or reversing it gave me 00 rpm . Note: i ve Changed the compressor 3 times and this problem still occur.
please help me...
Thank you Mike :happy:
Is it normal ?? because when pressing the brake pedal to stop the car suddenly the compressor disconnect and if i continue to press the brake pedal and not kicking the acceleration pedal it remain disconnect until the car remain idle or accelerate.
while reversing also when pressing the brake pedal also the compressor disconnect.
is it something with the electricity of the car?
Okay Thank you very much Mike :happy:
