Mods on a mk2... Springs,RARB & air filter questions.
Hi folks,
Can anyone clarify whether the Jabba 23mm rear anti roll bar fits the mk2 furby?
What lowering springs do you guys recommend? I have seen some eibach's but not much else.
What performance filter do any of you use? Piper, Green, K&N etc.
I know I won't get much, if any gain from this, but at least once it's bought you don't have to keep replacing every 5k-10k miles.
This is for on a 1.6crdi Monte Carlo.
Steve :)
eibach can be bought from skoda, approved and dont affect warrenty....
H&R are another popular choice for springs, and lower further... not skoda appeoved though,,,
I think the fabia I ARB fits... but not quite sure... some people had issues with it catching...
Are the eibach's from Skoda their 'sports suspension' option? As this wasnt an option on the monte.
I want something to lower it approx 25mm.
I know the 20mm whiteline rear bar specifies mk1 or mk2 without any differences... Wondering whether it's worth taking a punt on the 23mm Jabba anyway and seeing what happens...
Steve
Steve
The eibachs aren't the sport's suspension option, they are a separate dealer fit accessory.
I have also heard that the jabba rarb doesnt fit the mk2. I would go for the whiteline one as that one will definitely work :-)
Whiteline RARB fits the vRS fine, not sure about the Monte. As far as I know the Jabba one will not fit if you have a standard exhaust as it fouls on the back box. Someone has fitted one to a Mk2 but I think they have a miltek exhaust. I believe Jabba are going to design one but as yet it is not on the market.
I believe that the Skoda supplied Eibachs are only for the vRS, but could be wrong! Eibach probably do a set for the Monte and I assume H&R and others will do similar.
I think I'll look into the H&R lowering springs , but will hold fire on the rear anti roll bar, will wait and see what Jabba knock up!!
Still wondering what performance filter you guys are using? I certainly know my way round a 20v engine & Octavia, but still learning about the 1.6crdi and Fabia!!!!
Thanks for all the comments so far folks!!
Steve :)
Itg all the way when it comes to filters.
I have the Jabbasport arb on mine but it will only fit with an aftermarket backbox on the Vrs so you would need to check first as they charge a restocking fee if you try to return it.
Depending if your worried about warranty I'd get the h&r springs
