Difference in (octy)L&K and VRS Frnt Bumper...
Is it just the valance bit at the bottom of the bumper itself???
And can i fit a vrs on the L&K - any ideas where best to get one, either new or not?
And can i fit a vrs on the L&K - any ideas where best to get one' date=' either new or not?
Thanks[/quote']
It's the complete bumper.
Yes it'll fit, I have one on my elegance which is basically the same as the L&K. Mine was supplied and fitted by JBS. Best speak to Sarah for a quote.
Yes, although the black inserts are a different style (but I don't think they're a different size/shape).
The valance is actually moulded into the bumper, so you'd most likely be looking at removing your old bumper, removing the various bit of plastic trim, putting the vRS bumper on and then refitting the plastic trim.
You're sorted if your car is the same colour as a vRS comes in, if not then you'll have to look at getting one sprayed.
As to the best place to get one - depends how good-condition you want it. Anything that's been used will probably have a few scrapes on it, but will be quite a bit cheaper than a new one...
Rob.
Also, not all VRS's had headlamp washers where the Elegance and L&K did. So you'll need them to be transplanted too.
Yes it'll fit' date=' I have one on my elegance which is basically the same as the L&K. Mine was supplied and fitted by JBS. Best speak to Sarah for a quote.[/quote']
Cheers Eddy will do
yeah your right the L&K does have the headlight washers - but i will be able to get a vrs bumper with these or not? if not transplant time or just remove them?
Thanks guys, its good to be here :)
Oh and i believe mine comes in Black Magic - so yes for a vrs available colour - thanks
I have headlamp washers and they were just swapped over.
Helpfull guy as always :thumbup: Hows the 4x4 going after its saturday tweak ;)
VERY well thanks! :D
May be easier but not cheaper.
Can you rem what you paid off hand Eddy??? (when JBS did it for you)
Cheers,
Lee
Cheers' date='
Lee[/quote']
I can't remember but I think the basic vRS bumper skin is around
