emissions
Hi, I need to pick someones mind, my 2001 octavia 1.8t vrs has just failled it's mot on the emissions . The mechanic suggested a new front lamba sensor so I bit the bullet and bought one and had it fitted, the car failed again, same problem, so a new catalytic converter was suggested, again bought and fitted, same result although emissions were greatly reduced but still over the limit.
The engine was remapped about 3 or 4 yrs ago, I bought it 2 yrs ago, it has passed the previous mot's with the engine remapped but not this time. I have run some injecter cleaner through it, fitted new coil packs and spark plugs and the engine is flushed out on every service and now and again I give it a good thrash to clear out the cat of any crap that may not have been expelled by my normal gentle driving style and I am now seriously short of cash.
If anyone has had a similar situation or knows of a cure for this problem I would very much appreciate your help, oh and by the way I have never had any dash warning lights come on.
My best regards to all briskodians,
Ian :sweat:
I'd start by using VCDS to determine what fault codes, if any, are logged, rather than randomly throwing parts at it.
Can you post up the readings as well. I tested an Audi TT with 225 BAM engine in it a while back and the CO was way over at 7%, the fault with that turned out to be a disconnected fuel temperature sensor, that didn't have a warning light on either.
I had the same problem at my last mot. Ended up taking it to skoda and having them flash my ecu cos of a **** r tech map in it.
Remap was making it overfuel way to much. Get someone who knows what they are doin to check your fueling mate
