Tyre Pressure - Fabia MK1 Standard
Hi,
What pressure should be put in the tyres of a standard Fabia vRS in PSI? I currently have 32 PSI - I'm I at risk of blowing my tyre up?
32 sounds about right
35 front and 34 rear is what i was told from my tyre fitter
Go look inside your fuel filler flap, they're all listed there. I've found on my tyres I run 2.5 bar at the front and 2.4 at the back, but that's because the sidewalls are a little soft. Probably suggest for most people that 2.4 bar up front is more than sufficient.
Should be 33 psi front and 30psi rear. More weight on the front so more psi needed .
There was a table on this thread, but I think it's gone.
http://www.briskoda....tyre-pressures/
At the bottom is says for the 1.9 TDI PD 96kW, normal (unladen) 2.3 Bar (33PSI) front and 2.2 Bar (32 PSI) rear, and that's what I run. I have written the PSI figures with marker pen on my fuel flap as they only in Bar.
Fully Laden 2.5Bar (36PSI) front 2.8 (41PSI) rear.
Edited by Jim H
