Convenience module
Hi all
Where is the convenience module on the octy?
My brother has an issue where the interior lights dont activate when he opens the driver door.
It's behind the light switch, need to drop the lower panel.
Thanks Ross :-)
Also check the switch which is part of the door latch mechanism as there prone to failing
Where would I find that switch mate?
It is part of the latch built into the lock mechanism and usually requires a full new assembly,think someone on here fixed there's by replacing the switch but you could try spraying it with electrical contact cleaner first as mine stopped working and I gave it a good soaking and mines started working again for now
