Removing ac control knobs
Remove the trim, first take off the two pieces to the side of the aircon controls first -pull gently from the bottom edge then you can take off the middle piece with the controls on
Edited by greenstripe
Does it matter which position the controls are pointing?
From memory I don't think so. However I would set them all to 12 o clock or a position that is easy to remember for refitting. I remember it being a bit fiddly to get off and back on again. The main thing is to take your time and don't force anything. There's a lot of brittle looking plastic in there.
Just pulling is enough, I tried on my Roomster
