clutch upgrade
hi all again
i tell you what this site is really helpful now i have the engine running sweet and the handling all set up now its time to look at the clutch as she is starting to give up on high boots i have read on here the vr6 clutch will go in but i am guessing it aint a straight bolt in part cuz from what i can see you need to change the flywheel? or will it fit the old one also is there any other clutchs that will fit and take the pressure
Google is your friend
VR6 clutch from here http://www.vwspares.co.uk/g3clutch.php bottom one at 110 quid
G60/GTi flywheel 028105269BX about 160 quid with surcharge you have to pay
Flywheel bolts N90206103 x 6 about 3 quid
Clutch bolts N10101001 x 6 about 3 quid
Well worth doing and makes the clutch alot lighter and more bearable in traffic and its stronger to boot
thanx everyone you have been a big help
i use this on my stage 2 car http://www.ebay.co.u...#ht_2030wt_1271
How does it feel to use. Lighter than the oem clutch ? How many miles have you covered so far and are you happy with your upgrade ?
BUMP just for scotty96
