Problems with doors
Hi
Sometimes when I want to close the doors from inside or outside I have to pull or push harder to close them properly. What should I do? Can I fix myself this problem?
I've checked my friend s golf mk4 doors and you don't need to push them and they close themselves.
Constantin
Does this happen with all your doors?
You can fix this yourself but you might end up with misaligned doors depending on how much you adjust them.
There is a u shape latch on the chassis door shut with 2 torx head screws, loosening these 2 screws will allow up down in and out movement, you would need to slide it out towards the outside of the body to take some pressure off the rubber door seals.
