HELP : Radio stuck in PHONE mode.. wont re-set
My Supurb radio now says PHONE and wont play music or turn off
What do i do ??
Iv pulled fuse and re-entered the code and it still says PHONE in the top of the screen
Please help
If its a Columbus try pressing <, > & eject at the same time.
Similar reboot is not possible on Bolero AFAIK.
Sorry. No idea on that one.
Not even sure what it is!
Does it go back to radio if you pull fuse F8?
That's the MFD1 satnav (AKA Blaupunkt DX), 2 generations before the Columbus.
Do you have a phone kit fitted, its possible that the tele-mute on the kit has failed.
I seem to remember that the mute is done by the car kit grounding a wire, so could be a short also (if the insulation has chaffed off somewhere).
The none satnav symphonies allowed you to turn the muting off i think, so if you can get in to the menus.....
It must be behind the unit.. as we have never connected a phone ever
So it must have an external Bluetooth unit
Cant get into the bluetooth menu... only 1 and thats just a volume control
Iv not had one fitted myself.. it might be factory fitted.. id have to take the radio out to see for a kit du think ?
Edited by Tim_davies-moss
Just Disconnect battery, problem solved.
- there's no bluetooth menu on these units
- as your car's an Octavia I, then it would seem someone has retrofit this (pretty sure wasn't available as factory option :think: ) so quite possible some phone kit behind there somewhere...
How long have you had the car with it working OK?
its been fine for the 12months we had it.. but it went in for a new alternator and done it ever since
tried that.. dont re-set
must be an earth shortage then.. i did fiully expect the battery trick to work.. but no
think ill have to get the unit out and disconnect any bluetooth unit i find behind it
Hm an alien radio that is...
Yep
