Are VRS front springs the same as the other diesels?
Daft question probably, I have a 51 SDI estate. With a broken N/S/F spring.
I also happen to have a set of VRS springs and shocks.
Now, I could change the lot but are the actual springs at the front the same anyway?
Looking online it would seem that most of diesel MK1 fabia's share the same part number for the front spring, just wondering if they are the same part or if they are different (height, rebound etc.)
If anyone knows for sure I would be delighted to hear from you!!
Cheers,
Ben
I have an 03 SDI estate fitted with VRS springs on the front. I think you will find, as I did that the VRS springs will actually raise the ride height as the engine is not as heavy. To even things up I fitted heavy duty rear springs which popped the rear up slightly as well.
