windscreen wipers knocking
my drivers side windscreen wiper seems to knock on the window edge its getting annoying but it doesnt do it every time it sweeps
bump
bump
Is that the noise it makes? :D
I haven't noticed mine doing that although the sweep does seem to touch the very outer edge...
no its more of a click lol only does it while driving i think too :S
Get the dealer to look at it for you, if it continually does that then surely it's gonna chip away at the paint on the a-pillar... :thumbdwn:
i know i was fearing that but im not sure if its sweeping that far thomaybe its just banging the rubber
Operate the wipers whilst spraying the window with water (hose etc.) and see where it's likely to be touching. I know it only does it when driving, probably the force of air pushing it further but it'll give you an idea... :)
Or get shorter wiper blades :D
might have known you would be along soon enough lol might just chop them lol but i want piaa wiper blades :D
You may find that the airfoil on the driver's side wiper is actually hitting the passenger's side wiper arm as it sweeps to the nearside. On my wife's Fabia this happened in heavy rain and on the high speed wiper setting. If you look at the wipers when they are parked you will see that the airfoil is very close to the arm; it might even be touching it. The cure was to slightly re-adjust the position of both wipers on their splines and to file a bit off the airfoil.
i had the exact same problem, got really annoyed and took the car to the dealer, turns out my blades were Bosch aftermarket blades and about 10 mm longer than the VAG stamped blades, changed them, and i must admit it is better but im styill not happy with how close the wipers come to the A pillar
mine are bosch too!!!!!!!! thats the problem then
mine are bosh but mine dont hit the a pillar :)
yer a git then ;)
