fans cycling on and off with engine stopped
Just replaced the radiator fan and control unit on an octavia2 (earlier fan was jammed) car started ac switched on fans working fine after driving for 10 kms stop the engine fans keep cycling on and off continuously until the battery is disconnected any ideas anybody thanks
Happened to me a while back. moisture had got under the fuse box and subsequent corrosion had started shorting the fan circuit.
Do a search here - there are a few cases of it happening.
