Fabia Amundsen Memory Card Compatibility...?
Before i go out and buy one...does anyone know whether the Amundsen radio in my 2012 Fabia VRS will accept a SDXC memory card. I've used a 32gb SDHC in it before, but want to get a 64GB one now, and they are only made in the SDXC format...Thanks in advance...
I always used the SDHC doesn't it say in the user manual ?
Difference between SDHC and SDXC is the name itself and the memory it can contain.
However, the format XC use (exFAT) might not be compatible with the car!
That is not a problem tho since you probably have a phone / camera which it works in.
Use that and a nifty program like fat32format and it will use fat32 instead =).
There, it will now be able to use the memory-card despite not having support for it!
(Tested on an Galaxy Tab which is claimed to have a restriction off 32 gb, but that is because it doesn't support exFAT)
Thanks...had a couple of 64GB USB3 pen drives kicking about. So i formatted one to FAT32 instead of EXFAT and used it with the midi cable, it works perfect, thanks again for the advice...
If you have midi then harddrive would be just as gd,
