Loads of black smoke when come on boost
Every time I come on boost there is loads and I mean loads of black smoke and power drops aswel put under little boost it is ok and there is no noise from turbo
Boost leak?
Check all the pipes to and from the intercooler, see if there is any movement in the joints or signs of oil leaking out, especially the ones that connect to the intercooler.
I have had a quick look and they seem to be all look ok mate will have a really good check tomoro mate
Sounds like a boost leak to me. My van has one at the moment. :(
I am hoping it is just a boost leak
Main one to check will be the one from the turbo to the intercooler, give the joints a good tug!
Just been out in the car and it got no boost at all
Boost Solenoid i think its called?
Don't say that mate I have just sold me spare one lol
Get it checked for fault codes.
Will it still pick up because there is no engine mangment light on
Yes. You can get a lot of codes stored without a light coming on.
Checked all pipe work witch is very solid and done a run with a boost gauge in and only could hit .5 of a bar then it would smoke and u could feel the power drop
Log channels 11 & 3 in VCDS.
