Fabia vRS - need confirmation of brake disc/pads
OK,
i've had a search around here and there seems to be a bit of conflicting information, so I was hoping that someone who has actually ordered and fitted brake discs/pads from ECP could confirm the correct part nos.
I will be getting a local indy to fit these so can't take a hit with the wrong gear.
The bits i'm looking at buying are:
Front Discs (Part Number: 104440798) - http://www.eurocarparts.com/ecp/c/Skoda_Fabia_1.9_2005/p/car-parts/brakes/brake-friction/brake-disc/?104440798&1&d4bd70ae5a9e5a77c4832a10e9d1dde567e978c3&000027
Front Pads (Part Number: 101440418) - http://www.eurocarparts.com/ecp/c/Skoda_Fabia_1.9_2005/p/car-parts/brakes/brake-friction/brake-pad/?101440418&1&3712b731285652f2306c20ba07419ac6609ee3f8&000036
Rear Discs (Part Number: 104440748) - http://www.eurocarparts.com/ecp/c/Skoda_Fabia_1.9_2005/p/car-parts/brakes/brake-friction/brake-disc/?104440748&1&6c0b488ed75c1834e6e43c95bb3fd60ca6ef41f6&000027
Rear Pads (Part Number: 101440328) - http://www.eurocarparts.com/ecp/c/Skoda_Fabia_1.9_2005/p/car-parts/brakes/brake-friction/brake-pad/?101440328&1&45c1df77fe33f5f357af70a5211d6ec8181c0d18&000036
Thanks for any advice guys.
Why not just put your reg in and let it bring up the right parts for you? :S
...because it doesn't! It offers a "choice" of parts fitted to a Fabia not a VRS specifically. ECP's customer website will cheerfully allow you to order 239 or 256 mm front discs or pads. It's pants!
@OP, I think your front pads are wrong. I think you need this shape...
http://www.vwspares.co.uk/product_info.php?products_id=101
J.
Hi, I bought some OEM parts from Skodaparts.com discs were similar in price, however the centres are painted so no rust on the centres :)
Reserve online to collect in store and use BRISK25 to save 25%. :)
Not sure if it works in store, but it saves having to ask/faff around!
25% is nice though ECP have regular better efforts. I picked my full set of Pagids up for £100 with a 35% offer last month. More usual to see the odd 30% offer floating about.
J.
J.
Ditto but got 312mm front discs and pads plus standard rears for £115 all in.
Good choice with the Pagid parts. Why faff around wondering if you have the right size parts, just go into a branch and buy them with the discount code.
http://www.vwspares....products_id=101
J.
So these ones then? http://www.eurocarparts.com/ecp/c/Skoda_Fabia_1.9_2005/p/car-parts/brakes/brake-friction/brake-pad/?101441398&1&2a19409108237b6b72d9b2160706125617b4f2ec&000036
ECP site is a tad confusing!
J.
I'll be honest I just assumed they would be right after putting my reg in and received the 239's :blush: , they swapped them over no probelem though. Just make sure they are 256 in the description and you'll be fine. I got pagid pads and the eicher discs, pads grip great and discs are fine! I painted mine silver around the edges to stop them going rusty.
Shirley you mean 288mm front discs for the VRS?
