Quick one - fuel cap rubber lead broken...
the rubber lead on the fuel cap is broken, trying to find a replacement. Does anyone know what good words to search for? lol
Mine too, I pulled it off after it snapped a year and a bit ago.
But it still 'clips on' to the top of the flap when filling
using the little 'teeth' so I never bothered replacing the strap thingy.
I expect Skoda supply them. I guess the diesel rots the rubber.
Should have nicked the one off the SDI before I PX'd it. :doh:
  • Sponsor
It looks like you have to buy a new cap with the retaining strap if you go to Skoda/VAG. Here's all the relevant stuff from vagcat.com:
17 191201557
seal
18 107201551FD
lock cylinder for filler cap / * key code number and/or * * chassis number must be * * quoted when ordering * / also use: / only for:
PR-2W1 1J0 201 550 01C CODE 62 / FAB
(18) 107201551DA
cap, lockable for fuel tank / * key code number and/or * * chassis number must be * * quoted when ordering * / only for:
PR-2W1 42,11,12 / HUF
(18) 1J0201550A
cap with retaining strap for fuel tank / for vehicles with central locking system / F >> 6Y-3-800 478*
PR-2W0 /
1J0201550A 01C
satin black
(18) 1J0201550AC
cap with retaining strap for fuel tank / for vehicles with central locking system / F 6Y-3-800 479>>*
PR-2W0 /
1J0201550AC01C
satin black
(18) 1J0201550
fuel tank cap / (for service installation) / also use: / F >> 6Y-3-785 572
PR-2W1 1U0 898 007 /
1J0201550 01C
satin black
(18) 1J0201550AB
fuel tank cap / (for service installation) / also use: / F 6Y-3-785 573>>
If you look very closely you can push out the two plastic pins using a needle from the cap which holds in the rubber strap. Then you can replace just the strap.
You can't buy the strap seperate though.
Just buy a new cap, as above comes with new strap, mine broke on my Octavia at 4 years old, mind you a remapped petrol gets a lot of fills a the petrol station :blush::giggle:
