Alloy Hose couplers
The alloy connectors are just an alloy version of the plastic on the OEM hoses, they are better and retain the OEM flat o-rings to seal the joint.
Had them on my 05 PD A3
Paul
You just swap over the rubber o-ring and insert the alloy coupler into the plastic Intercooler hole. There is a slide in clip which goes down a channel in the Intercooler to lock it in place.
