d90 alloy help and indicator help
hi all i.m putting d90's on my fabia vrs my question is what will i need to space them by??
front is 6j rear is 8j so am i ok running 20mm rear spacers and 15mm up front will it rub ill be running abit off stretch thanks
also what fitment is the indicator bulbs for front and rear off vrs i'm wanting to order silvatec bulbs to get rid off orange
the amount of spacing will depend on the et of the wheels to start with and if you want em to poke or tuck.
porsche wheels have high ets i believe (et 50 maby more) so fitting 20mm adaptors would bring it down 20 to et30 ( that's just an example).
Google "will they fit wheel calculator" . . put in existing sizes and new ones and it'll work out how much more poke you get compared to standard.
For reference, I'm running 7j fronts and 8j rear d90's with 25 mm spacers up front and 20 mm rear. Tyres are 195 's (stretched). This set up sits nicely in the arches.
I'm running 7.5j upfront with a 40mm spacer and 9j rear with 25mm spacers. Plenty of poke to go with some insane stretch!
cheers lads yea d90s are offset 52 my car is quite low so i dont want any rubbing as far as im aware standard tyres are 205s so 195 will give abit off stretch yea?? i was thinking 165/50/16 tyres but i recon that would be to much so i think ill go with 20mm rear spacers and 15 upfront for rubbing issues
  • 1 year later...
Hi lads i dont understand that Much about cars but I am about to get some d90 for my fabia what do I need for them to fit spacers or adaptors ?? Sorry about this stupid post but can somebody tell me what I need and the prices cheers :)
You need adaptors. . 5x100 to 5x130 . . Width of them depends on how you want the wheels to sit.
For a set off 4 good ones at least £200
