Autoglym products... recommended alternatives please
Where is the best place to buy Collinite 845 Wax then? the links provided are they where you guys purchase from?
  • Replies 54
  • Views 9.2k
  • The fundamental difference between 845 and 476s is that one is a paste and one is a liquid wax. The 845 and 476s are made with the same ingredients, but the 476s lasts longer due to the fact that it
  • Yes...Youre right Babs AGSRP is a good old favourite and to a lesser extent only...AGEGP is OK...ish Both,as you say, readily available..Halfords, most Motor Factors BUT There are alternatives that
  • You da man, thank you very much!
As I don't get on the forums at the weekend and ChrisRs has already suggested two sources I will just add one more into the mix.
Elite Car Care do a nice little kit:
http://www.elitecarcare.co.uk/collinite-845-liquid-insulator-wax-detailing-kit.php?manufacturers_id=26
Or you can buy it on it's own:
http://www.elitecarcare.co.uk/collinite-liquid-insulator-wax-no-845.php?manufacturers_id=26
Use discount code DW for 5% off...........;)
  • 4 weeks later...
If you've got white residue on plastic bits, I have a solution which I use and is far cheaper and easier than buying special trim cleaner, etc. Rub the plastic part with a large pencil rubber/eraser. It works a treat. :thumbup:
Thank you for this tip, finally got rid of the SRP marks on my window rubbers, body rub strips and wing mirror mounts (I created them when I first started out with this detailing lark!)
