Wishbone bushes
Nope need to come off. Youll need to drill them out and repress these in
yup, would be an absolute nightmare to even attempt to do!
fair enough, am I correct in thinking that I need to change three stretch bolts on the wishbones? If so, anyone know the part number?
if its the firstime they been off you could use them again but if you wnat the pn for them :
Remove the ball joint bolts x3 and the bolt into the subframe, and the nut n bolt too
pn:
I take it you still on the std wishbones?
Front bolt N 904 840 03 (x2)
Rear Bolt N 102 622 02 (x2)
Rear Bolt Nut N 015 081 4 (x2)
If you want new bolts for the ball joints? N 101 277 07 (x6)
USED THESE FOR A COUPLE OF YEARS AND STILL GOING STRONG ON MY VRS :) ooops shouting about it
