Alarm led
My alarm led is not working,i have had the door panel off and it is plugged in ok ,any ideas???
The alarm isn't activating? Can you set the alarm and test it works?
Windows Down, lock car, climb in through window
Checked the alarm,it works fine, it's just the flashing led thats not working :wonder:
Anyone??? this is driving me nuts :wall: i know its only a minor thing but it should work and i doesnt.Did a scan with vcds and no issues although there may be a way of testing the led with vcds that i'm not aware of.
Had a word with the stealers and they are quite happy to charge me to check things out and if its a wiring fault they said it wouldnt be covered by the warranty.
Come on guys,someone else must have had this problem
The led could be kaput
It may be in the output tests of the module that the Led is connected to. Have a look in the output tests of any relevant module (door module, central electronics module, convenience module or alarm module).
Paul
  • 3 months later...
did u get it sorted ? mine doesnt flash either !
