beepin noise on vrs furby?
sometimes i hear a beepin noise when drivin around in my vrs? its like a long beep then it gos? what is this?? :confused:
Not beepin' the horn are you? :)
the beep will be a warning for something not right, check out all your warning lights, and anything else that may go wrog... for example, if you drive off without removing the handbrake properly it'll blee at you!!
no its not commin from the dash? it sounds like its commin from the passanger side of the dash? its strange? dosent do it all the time.
Most common long beeeeeeep for me is washer bottle empty or fuel low. Both have pretty obvious warning lights on the dash. Could be a light out or the dreaded high-level brake light cluster going, which'll give you a beep, but only when you brake (obviously)
must have got me mixed up with someone else mate, i havnt had any probs really with mine. only havin wrong gear knob on when i picked it up!
Handbrake still on when you move away? Don't know where the beeps actually come from - mine seem to fill the car and scare the **** out of my passengers ;)
Chris
its not as loud as when your fuel is low? its as if its comin from behind the glove box? like i said its not there all the time, but when it happens it confuses the hell out of me?? :confused: :confused: :confused:
Is it a really quiet, distant one? I've got something similar from outside the car (I think) very occasionally.
Does it only happen when it's cold?
yes! really anoying because everytime it happens i think it comin from a different place?
Not sure if it's cold only as it's so quiet and intermittent.
How about recording it and putting it on the site ?
