Engine temp drop and management light on
As title says I have an engine temp drop and the orange management lights on again, any ideas as to what it may be? Hope you guys can come to the rescue
Coolant temp sensor?
May be worth getting a diagnostic done
You could check to see if you have a black coolant temp sensor , if you have just change it for the green one
If I am still sad , the part number is 059 919 501A , just approx £20 ish , so worth checking that first
The CTS is a 4 pin sensor , 2 of those pins work the temp guage
It was a common issue and the part was superceeded
First thing I bought for my son`s Golf when he got that , as they was so common
Good luck
Sarah
Cool will get on it tomorrow. Can the car still be driven?
I can't see why you can't drive the car.
As already stated the CTS is a 4 pin 2 output sensor. One output is to the temp gauge the other is to the ECU, it is common for 1 or both sides to fail on the old black type which is no big deal if it just effects the temp gauge, but much more troublesome if the ECU side has gone down as the ECU won't fuel correctly. Replace with a genuine green VAG sensor & not a cheap aftermarket version or you'll be buying a genuine one soon after.
Ok cheers, the wife's gran loves the car and always bags passenger seat :)
