trembled very much
Hello. I have a problem with the car Octavia 2.0 TDI
I trembled very much when the car is removed from the engine speed does not matter if cold or hot .... and when slowing down at traffic lights and let the free flow makes a tractoras engine stops working uniform gives to die like. I did ... about three testing in various places and nothing .... I thought it was the flywheel and I changed it and all ... I changed the clutch and turbo it as whistling ugly .. and I changed nothing ... and he fails the compressor and nothing .... I cleaned two days ago and with all the EGR valve below it and anything that makes it worse ..... if problems arose once the flywheel followed by an "emission workshop" who disappeared after I ran a little.
Please help me. Thanks
Wow!
Yep looks like something out of a translator.. Just shows what a great and far reaching site this is!
Half past four.
Duce?i-l la un garaj bun.
Its very hard for us to understand your problem. Your english here isn't good. If you can explain your problem using different words we can help. Try short sentences.
Do you have engine shaking? I see you have replaced a lot of things and its still shaking/trembling. If you can be more clear, we can help.
I tremble too when my car is away from the engine haha
ok i think what you mean is when the engine is at idle no matter whether hot or cold, it idles rough and feels like it wants to cut out?
Has your car had the injector recall? sounds like that could be it.
