Goosed Throttle Body?
Started up the Roomy the other morning after the long and spirited drive down to London for the Grafitti Tunnel Meet and had an EML with 'Exhaust Workshop' popping up on the maxidot.
Ran a scan today and it threw the following codes (not included full scan as all else was clear)
Monday,26,November,2012,15:47:08:26358
VCDS Version: Release 11.11.4
Data version: 20120807
Chassis Type: 5J - Skoda Roomster
Scan: 01 02 03 08 09 15 16 17 19 25 37 44 46 55 56 76 77
VIN: TMBN************* Mileage: 105720km/65691miles
Address 01: Engine Labels: 038-906-019-AXR.lbl
Part No: 038 906 019 NR
Component: 1,9l R4 EDC 0000SG 9134
Coding: 00102
Shop #: WSC 73430
VCID: 74ECCCF344DDD9B835D
TMBNG65J285059216 SKZ7Z0H4700052
2 Faults Found:
19557 - Motor for Intake Manifold Flap (V157)
P3101 - 35-10 - Open or Short to Ground - Intermittent
19559 - Motor for Intake Manifold Flap (V157)
P3103 - 35-10 - Malfunction - Intermittent
Readiness: 1 2 0 0 0
Address 03: ABS Brakes Labels: 6R0-907-37x-ESP.lbl
Part No SW: 6Q0 907 379 AP HW: 6Q0 907 379 AP
Component: ESP 8.0 front H03 0001
Revision: 00000000 Serial number: 00000000000000
Coding: 0000284
Shop #: WSC 73430 790 00000
VCID: 8B1E370FE9232640C47
No fault code found.
Address 17: Instruments Labels: 5J0-920-xxx-17.clb
Part No: 5J0 920 940 C
Component: KOMBIINSTR. V2824486
Coding: 19402
Shop #: WSC 25063
VCID: 2A50128BD699DF485F1
1 Fault Found:
01336 - Data Bus for Comfort System
80-00 - Single-Wire Operation
Reading the threads HERE and HERE the prognosis looks costly :(
Anyone any thoughts??
Guest
