VNT17 onto PD100
Lummox, could you estimate how much it would cost to fit vnt17 to my fabia tdi pd100 which involves fabricating new flange to attach exhaust too. is it as simple as that
Add to that remap, plus poss pd130 injectors.
Any idea would be great
Thks
John
not at all off topic :rofl:
IIRC the exhaust should bolt straight on.
Remap around
edit
Thread split into its own topic ;)
I was told PD130 injectors used "different cam" in the block, so went the whole hog in the end. This fact put me off going for injectors alone. I would have thought a VNT17 would bolt straight on too. Matches at both ends dunnit? :D
Cam would be in the head J :)
eh? :confused: So injector is not related in any way? Someone somewhere... :rofl: ... told me the pd130 injectors used a different cam, so wouldn't work right in the ATD engine... :)
Yes the cam is in the head along with the injectors. Are you sure you should be changing this engine..lol.
Well, I'm not the one doing it - just trying to get my head around why I was told pd130 injectors wouldn't work with pd100 cam, etc :confused:
Turbo seems easy enough though.
Possibly because the lift or the duration of the cam is not suited to them.
Yeah, that could be it. :) Wanted to try and clear this up before John fits anything to his engine which might jeopardise it.
It was me who said that.. because as Lummox said there MAY be differences that would screw up...
and "MAY" is not a word I wish to hear when doing what I'm doing! :thumbup:
A bit like "PROBABLY" and "DAMN, IT WON'T START UP!" :rofl:
Hi, I haven't seen the turbo so I have no idea if it will fit.
I got it sent directly to allard's.
Allard's are looking into injectors and the like and I hope to hear something from them latest early next week.
I'll update then - thanks for splitting the reply's
John
