rear wiper blade
Never use rear wiper blade but reversed car back in garage and it came on but noticed it only removed about 4 cm of muck!
had a look and it looks like the rubber has gone out of shape or warped or something
so need a new blade but carnt see how the bugger comes off!........help
They just unclip.......... RTFM.
ive pressed and prodded but nothing is moving
lift the wiper arm off of the window, pivot the blade 90 degrees to the arm, push the blade and it should lift out.
Lift it up and use a power washer, generally that'll knock the bugger off whether you want to or not. Crappy piece of design imho.
sorted.............cheers mate that worked just placed an order online £10.75 inc post and packing.........
The combi one for mine was £5.?? from the dealer.
£5??... mine was £12 for the hatch both the same wipers too.
my blade was about £12 too. Bought bosch flat blade's front and back for about £35.
£5 is mega cheap imo...too cheap tbh
My new rear wiper was £8 fitted at stealer (Estate).
Never thought I'd recommend Farmers in Leicester....
They also supplied and fitted a new fob battery for less than Halfords were selling them.
my rear wiper blade was around £5.50 + vat from my dealer
I think that must only work for the estate. On my hatch the fronts do exactly that but the rear one has a small plastic cover that has to be pushed along so that the blade can be unhooked from a fitting on the arm. It is still pretty easy but does not work like the fronts.
That's what mine is like.
