H7 4,300K HID kit BNIP
I have for sale two sets (one set sold) one set of H7 35w 4,300K (the whitest kits available) HID kits with super mini sized ballasts (70mm x 63mm x 15mm)
They have the (better) metal H7 bases and ceramic insulation (they are the top ones):
One kit has been opened, the other kit has not been opened, they are not in retail packaging (fancy box) but are boxed.
They are non CANBUS kits so ideal for pre FL cars (without the BCM controller) just code the central elec. 09 controller for ‘xenons without shutters’ (BCM controllers do NOT have this option, so I cannot guarantee they will work on them)
this is the safer way of fitting HID’s as CANBUS kits can fry the wiper motor.
These need to fitted behind projector (round ‘eyeball’ inside the headlight) to prevent scatter!
Looking for £25 per kit
Assuming they'll be good for my 2008 Roomster with H7 projector single bulb lights.
I'll take a set. Let me know how you want paying :thumbup:
Yes they should be fine for a Roomster.
PM incoming.
If they fit my l&k mk1 octy I take the other set please
According to power bulbs the MKI Octavia uses H4’s ??
Ok thanks buddie of they are any good for me will take them
Will this particular kit be suited to the MK1 Fabia vRS? If so, consider the second kit sold...
They will physically fit the Fabia, but if you have normal reflector headlights (non projectors) then they will cause light scatter.
Your call.
OH!
how could I rectify this?
Thanks for your help and honesty!
I think you have 3 choices:
Fit H7R (I believe they are called) these are not meant to give off glare... The jury is still out on whether they are reducing scatter enough.
Fit projector headlights
Fit uprated halogen bulbs.
HTH.
I run the exact same ones in reflector headlights and never get flashed. Best colour too imo.
Just run them in the normal light but change to halogen bulbs for MOT. I can see the seller is covering his back though.
I drive for a living and see a lot of non projector cars with after market Xenons fitted and for what it's worth, you are causing glare to oncoming cars!
Just sayin'
Tapatalk'd from my HTC SXE Beats
Hi gizmo - would they fit my 2011 fabia vrs?
Just sayin'
When you see me, gimme a flash!
According to Autobulbs, yes yours are H7 bulbs, IIRC they all have projectors as well, there is no Fabia or Roomster with the BCM controller in the list I have so you should be fine.
I live in Ireland............I'll probably still be able to see ya :@
Think I may give them a go and see - if not, AdLav can buy them off me! :rofl:
Perhaps vrsrs is right, he bought my old car you see and I would have fitted them lol
A trip to see you pick them up may be in order...
Gizmo,
Any of these left? Cash and collect? ;)
All sold.
Guest
