High Beam toggle
Hi Again,
Another quick one... anyone have a guide on how I might fix an issue with switching to High Beams on the headlamps?
It seems the connection is a bit dodge and other day I was driving home and turned on high beams only to plunged into darkness.
If I push it a bit harder they come on so Im guessing the connection just needs a clean / sanding?
Thanks!
I was looking into this the other day, and some 'sole has kindly designed the steering colum shroud such that you have to remove the airbag and steering wheel in order to get the shroud off.
Well that rules that out for me then...
