noise when changing gear VRS
I've had my fabia VRS for about 2 weeks now and every time time I depress the clutch pedal and change gear there is a strange (the only way I can describe it is) a whirring noise coming from either the clutch or the engine.It is only noticable in lower gears at slower speeds anyone experienced similar problem .
Noooooo :confused:
Hmmmmmmmmmmm........... whirring noises worry me!
Anyway, I had a squeaky noise when changing gear. Thought it was a duff gearbox mount, but turned out to be a loose clutch pipe around the gearbox area. The airbox needed to be removed to pin point the culprit though.
