Map position way out on Columbus
I exported a contact in VCF format after having attached a pic to it (but no GPS co-ordiantes, just an address) from my mac onto an SD card- the option to import or navigate from SD card destination showed up as did the vcard.
However selecting it did nothing and the pic I attached to it also didn't show on the screen. So I tried adding the gps co-ordinates this morning by creating another field in the contact entry. This time when I tried to import it the unit seemed to freeze for a bit and then rebooted.
However, since then my position on the map is way out- I am currently in Coventry whereas my position on the map is showing as Leek Wooton near Warwick. I have tried both a hard and a soft reset but no joy. Is this co-incidence and may be a loose connection with the GPS antenna or have i done something to the unit by my aforementioned antics?
Can't see an option to reposition the gps - I think my freelander unit has the option as do most Tom Toms
Also cant find anything in the threads apart from one where the antenna was faulty
Anybody else experience this??
Gaurav
Hi
I've got this problem at the moment. Did you ever get to the bottom of it (or has anyone got any ideas please)?
Hi
Possibly a new Ariel required I'm on my third.
Hi
Hi
Mine resolved itself. Not sure what caused it or what improved things as I didn't do anything!
Gremlins??
My map position has gone way off :(
Have any of you guys found any answers to this one yet? Mine thinks I drive offroad a lot.
