HELP Octavia 1.8t vrs 2002 - Led Cluster For Clocks
Hi There
I am looking to customise my clocks on the octavia VRS. Can anyone advise
me on the type of leds I need to use and where to get them from.
Gaz
Hi Gaz,
You will do better posting your question in the Octavia Mk1 forum. I'm not sure if any of the techs will customise a dash insert. Diagnose and replace - yes, Customise no.
Will move..
Hi there i will remove once i can get on a laptop. Thanks for the info.
Someone will be able to tell you more specifically but what you need are the little square buggers called SMDs. You solder them in to replace the standard ones.
I recently changed the LEDs for Gee's rs estate. I'll get a link for the LEDs I used when I'm on the laptop
Thanks guys appreciated
