pass window
front passenger window is not lowering or rasieng anymore, can still hear the motor turning allmost like it is chewing a cable or some sort, anyone have any ideas as to what i may need to replace to get it working again ( lots of snow and rain at the moment and no garage to work in so need parts to fix not to strip then see what i need)
many thanks in advance fatbob
The motor is literally chewing on the cable. Search on ebay for window repair kits
I would advise that you only replace the part you need too, with the repair kits. I replaced the whole lot last time, and the cable end pulled out of the main plastic clip after only a couple of months.
A complete regulator assembly was only about £54 inc. VAT from TPS though, which I eventually was forced to fit. If you've got nowhere to work in, I cannot recommend highly enough that you do this, since the repair kits take a fair bit of farting about and struggling with, first time round.
cheers guys gonna start looking for repair kits if anything its confirmed that the cable os fubared but need to confirm
thanks peeps
