Octavia 2011 Estate updated headlamp conversion RHD to LHD
The pictures I've looked at so far do not resemble my h/lamp units apart from the white plastic nut. Can anyone help and save me driving into Norwich to the main Skoda dealer. I do like to do these jobs myself when possible. Many thanks hopefully
Edited by Peter Nurse
Hi and welcome aboard.
You need to remove each headlight from the car by removing the plastic nut and pulling on the release leaver, and then remove the plastic cover, inside each one is a single metal slider that needs moving to the opposite ends of its travel.
If you have a maxidot display you can alter the setting via travel mode in the menu, and turning this on.
NOTE: neither fully converts the beam to LHD and simply flat beams the lights. Although good enough for a short visit, this is not sufficient for long term use abroad and will fail the required tests in Germany if you are in the forces for example.
