Brake lights not working..changed bulb and fuse..still not working
As title, my brake lights are not working, changed bulbs and fuse, still not working. Does anyone have an idea what can be the problem? Replies are appreciated :-)
There is a switch in the pedal that activates the light. It also works with the ecu to close the throttle if you brake and accelerate at the same time.
Brake light switch is a common fail (above pedal).
Fixed :-) Was the brake light switch! Thanks for the help :-)
